Kawasaki Side by Sides Talk about the rugged Kawasaki Sport and Utility
2011 mule 4010 oily air filter??
Old 12-13-2014, 07:41 AM
essonlaker's Avatar
Default 2011 mule 4010 oily air filter??
the farm I work at has an 11 mule 4010, awesome work machine! but I noticed this week when I checked the air filter that It has a fair bit of engine oil in it.
what causes this? really hope there's nothing major wrong with the machine we kinda depend on it.
Old 12-13-2014, 09:01 AM
TLC's Avatar
TLC
TLC is offline
That happens, the Motor's crankcase vent hose connects to the air box and it get engine oil blow by. Happens more is you travel steep inclines or tip over.
Just clean it up once in a while.
Old 12-21-2014, 02:59 PM
essonlaker's Avatar
I looked and found no hoses going to the airbox
Old 01-07-2015, 04:00 PM
essonlaker's Avatar
okay so the shop my boss deals with for stuff he can't fix suggested the crank vent was plugged. and the filter shouldn't be oily. (there a kawi
dealer)
this has a paper air filter like a car and this seems like too much oil for any sort of normal circumstance.
I checked the oil and it looked fine. I located the crank vent hose and it goes into the throttle body. will check this for being plugged in the morning. there's clearly pressure in the case somehow.
Old 01-08-2015, 10:45 AM
TLC's Avatar
TLC
TLC is offline
A reason for oil blowing out the crankcase vent hose is a tip over and even riding up and down steep inclines.
Old 01-11-2015, 02:57 PM
essonlaker's Avatar
if this is normal then its a **** poor design on Kawi's part. the only case vent I could find was not plugged and it goes from the valley between the cylinders to the throttlebody, not the airbox. so the engine should draw in the fumes and oil instead of spitting it all the way to the filter. any quad that belongs to someone I know has case vents and doesn't do this. this means very frequent air filter changes or the install of a foam, cleanable air filter. the inclines it travels aren't ridiculously steep. my quads travel steeper inclines. and aren't effected.
kodiacrunner
10-04-2015 11:52 AM
highwayman
09-19-2015 12:59 PM
greg86hd
09-16-2015 12:32 AM
Nosniborpapa
09-12-2015 05:54 PM
ylomnstr
09-10-2015 06:45 AM
Quick Reply: 2011 mule 4010 oily air filter??
