2002 Yamaha kodiak 4x4 engine removal
Old Dec 30, 2014 | 04:13 PM
Alexsami0508's Avatar
Default 2002 Yamaha kodiak 4x4 engine removal
hey guys,
I got a quad for a really good price because it needs work. I must be dumb because I can't get the engine out. I have removed all connections, pulled the rear end and took all the engine bolts out except one that I can't figure out. It is the rear upper pass thru bolt. Took the nut off and the bolt won't slide out. It looks like there is a spacer/sleeve the bolt goes thru but when I turn the bolt the spacer/sleeve turns as well. I can't take off the engine mounts from the frame because they are welded on. Some advice please.
Old Dec 31, 2014 | 02:26 PM
I need some help please. I tried to drive it out today thinking it was rusted but all it did was bend the mount.
Old Jan 1, 2015 | 01:33 AM
Really no one has anything to say? Come on people. I need help please.
Old Jan 1, 2015 | 04:21 AM
I've been working on quads for almost ten years full time, and very rarely have had to remove engines. I don't do a lot with Yamahas but there isn't much on a Kodiak you can't get at with the engine in the frame, so few people on this forum will have removed a 2002 Kodiak engine.
Old Mar 29, 2015 | 05:06 PM
habsman's Avatar
Default Kodiak 4x4
Hello,
Since you are familiar with kodiaks.
My wheel drive has quit on my 2002 Yamaha kodiAk.
When I drive down the road I can feel the machine lift up then it seems to go back down.
Could this be the 4 wheel drive engaging and disengaging ?
Old Mar 29, 2015 | 05:19 PM
Originally Posted by habsman
Hello,
Your wheel drive?
Old Mar 29, 2015 | 05:22 PM
habsman's Avatar
Default 4 wheel drive
Sorry 4 wheel drive
Old Mar 29, 2015 | 05:30 PM
It really could be 2 separate issues. I'm guessing the problem you are having is carb related. A little more info on the timing of the issues would be helpful.
Old Mar 29, 2015 | 07:32 PM
habsman's Avatar
Default 4 wheel drive quit
When I drive down the road I litteraly feel the machine lift up, not a surge in power. The a few seconds later, the machine seems to come back down.
I also hear some clunking by the right frt tire.
I has some work done on the 4 wheel drive last yr, even though it doesnt work, it feels like it's trying to engage and disengage going down the road.
Old Mar 29, 2015 | 08:48 PM
sr.ruedas's Avatar
If you apply the front brakes only while trying to go forward, then the rear drive can lift the quad up on its suspension. I suspect you have some major drag in the front drive system. Does it also pull to one side or the other?
I just sold my 01 Kodiak project. Hit in the front, but one sweet-driving ATV, with full auto, and a very effective engine braking system. This was the nicest looking and driving utility ATV I have ever had.
MERRYMAN is correct that you rarely have to remove the engine, even with major damage to fix.
