Yama Breeze running rough / spark issue
Old Jan 1, 2015 | 11:53 AM
kyle887's Avatar
Default Yama Breeze running rough / spark issue
OK I started a new thread because I have diagnosed the problem a little more and I think I'm heading in a different direction.
Here's the problem...
-The quad idles OK, but once you hold the throttle open a little it runs rough, stumbles, and if you hit the throttle to 1/2 quickly it falls right on its face and dies. After about a minute of holding it at 1/4 throttle it will stall out (it surges up and down a bit if you hold the throttle steady). When it stalls out, IT LOOSES SPARK (I pull the boot right off the plug and use a test plug on the cylinder fins and find no spark). As soon as I either turn the key off/on, or turn the engine stop switch to stop / run, it instantly gets spark back and will fire back up. Then again, after a minute or two it will do the same thing and the cycle continues.
When it runs it appears to be a tad smokey, and smells like a poorly tuned engine.
Ive got a new ignition coil and CDI box in it and the trigger coil is ohming out around 260. The spark appears to be a little weak (not a big blue spark, rather a little blue/white spark). Ive inspected the stator for cleanliness and it appears to be in good shape.
Any ideas?
SOLOLUCKY
Oct 4, 2024 09:09 PM
Hankey Pankey
26
Oct 18, 2020 03:50 PM
wannabe32
Jul 7, 2015 11:30 AM
gfl0224
Jun 27, 2015 06:52 PM
Dabears1983
Jun 16, 2015 12:17 PM
