can't get timing right on yfm200
Old Jan 7, 2015 | 06:49 PM
Let It Rip's Avatar
Default can't get timing right on yfm200
The short version of the story is I needed to replace the cylinder head. Now that everything is assembled, I can't get the sprocket to set directly at TDC once the tension adjuster is installed. The TDC line on the cam sprocket either ends half a chain link before or after TDC point on the cylinder. I've strapped the ratchet to the frame so the crank wouldn't move,and I loosened the valve adjustment screws so the rocker arms would be loose. I've also tried setting the sprocket forward TDC by one tooth because I thought it would end up correct once the tension adjuster was installed but it still ended up half a tooth forward.
Any help would be really appreciated. I've been battling this for about 3 days now.
Old Jan 8, 2015 | 04:25 AM
That is as near as you are going to get so the engine will be OK with that. Highly tuned engines have "micrometer adjustment" so you can get them spot on but a quad engine doesn't need to be that accurate.
Old Jan 8, 2015 | 04:46 AM
I've worked on a lot of Japanese engines over the years whether they be single or dual cams that you just couldn't get the marks to line up perfectly even if you had a new cam chain and sprockets. On some dual cam models one sprocket mark would be parallel with the cylinder head,the other sprocket mark may be up a little,but as close as you could get it.
Old Jan 8, 2015 | 06:04 PM
Let It Rip's Avatar
Thanks for the feedback. It's had me frustrated since sunday. So I guess the backfiring through the carb is related to air/fuel mix or valves, so i'll tackle that tomorrow.
Old Jan 9, 2015 | 08:07 PM
Let It Rip's Avatar
I've got another question for you guys. If I can't get the timing exactly at TDC, would it be better for the timing to be half a tooth advanced or half a tooth retarded?
Old Jan 9, 2015 | 08:10 PM
Don't think it would matter that much either way,but when I came across one like this, just out of habit I would leave it 1/2 tooth advanced rather than retarded. But that's just me..
Old Jan 10, 2015 | 12:59 AM
Let It Rip's Avatar
Thanks, should I set the valves to standard or leave extra clearance to keep the piston from slapping the valves? I figured I would stab it together, give it a whirl and hope for the best. With the engine being 30yrs old, if it gets ruined so what.
Old Jan 10, 2015 | 08:22 AM
Don't allow any extra clearance. Just set them to specs and go from there.
Old Jan 14, 2015 | 03:25 PM
Let It Rip's Avatar
Thanks for the help. It's still 1/2 a tooth off but runs like a champ, no backfiring and starts easy.
Old Jan 14, 2015 | 05:20 PM
Usually no problems when you get it this close on cam timing. Glad it's running ok for you.
