95 foutrax 300 rev issues
Old Jan 31, 2015 | 11:26 AM
Jaster94's Avatar
Default 95 foutrax 300 rev issues
It's driving me nuts, maybe I can't see the forest cause of the trees😜, but the old quad fired up, carb cleaned multiple times. Shows no signs of vacuum leaks, yet when revved up, it cycles up/ down like you shut the key off& immediately turned it back on. Guess I'll see if the float is jacked up, all I can figure for now
Old Jan 31, 2015 | 11:54 AM
Jaster94's Avatar
Kinda like.....pulsating quickly within 100 RPMs up/down
Old Jan 31, 2015 | 01:01 PM
Jaster94's Avatar
Wow. Float is good, no vacuum leaks, still unsure of pulsating issue...jets are clean, I'm still missing something but what?
Old Jan 31, 2015 | 09:06 PM
papa hogg scoot's Avatar
Loved
Community Favorite
May try looking in the air snorkel to if critter has built an nest restricting air flow or take airbox lid off to if runs better if does then check the air snorkel for dirtdobber or rats nest
Old Feb 1, 2015 | 04:58 AM
Sounds like the rev limiter is coming in. If it comes in at lower revs than it should the CDI may be on its way out. Some bikes also have a lower rev limit when in reverse, can't remember if the 300 has but, if it does, faulty reverse wiring can cause this too.
Old Feb 1, 2015 | 05:42 PM
Jaster94's Avatar
Thanks, intake is all clear as also the exhaust, I was leaning towards limiter but was unsure, thanks for the replies!
Old Feb 1, 2015 | 07:13 PM
Loved
Community Favorite
try new spark plug first before replacing CDI box..
Loved
Community Favorite
Is atv charging good?
Old Feb 1, 2015 | 08:40 PM
Jaster94's Avatar
I'll hookup my multimeter, didn't think about stator output
Old Feb 1, 2015 | 09:34 PM
Loved
Community Favorite
check at batt bout half throttle
