Yamaha bear tracker 250 HELP!
Old Feb 16, 2015 | 03:40 PM
Williambruce's Avatar
Default Yamaha bear tracker 250 HELP!
So I bought a non running piece of junk atv for 100$ with ramps... Owner said some engine problem I didn't get a chance to turn it over when I bought it so no idea what's wrong. Finally got the pull starter to work and it turns over good until a certain point and it stops and will not turn over any further. I'm pretty it is out of time because I see the intake valve coming down and the piston coming up and it stops (looking through the spark plug hole). So I take off the left side of the engine removing the stator and the flywheel with the starter gears and I can't get the timing chain off. I've took off the tensioner and I have removed the cover over the cam shaft too and tried to take off that gear but nothing is working. I need help ASAP!
Ean
Dec 19, 2022 08:48 AM
STLyamwar
Jul 25, 2020 04:44 AM
Ean
Aug 28, 2015 09:39 AM
austinwhitton
Aug 11, 2015 06:21 PM
Peter_
Jul 18, 2015 07:06 AM
