Headlights stopped working
Old Feb 26, 2015 | 12:41 AM
Brian Loftin's Avatar
Default Headlights stopped working
I have a 1999 polaris sportsman 335 4x4, the headlights quit working, all 3 went out at the same time and will not come back on, does anyone know what to check to figure this out.
Old Feb 26, 2015 | 08:02 AM
Check the high beam connector in the lower pod. Connector wiring has to bend up and a is good place for shorts along with connector problems. Plus low beam green and brown wires split under the front panel to go to each side and usually zip tied to the front frame under the fender. Anther place that can cause problems.If any bulbs have shorted out,match them up at any auto store.Plus you might want to clean the connectors going to the left control switch plus use a little dielectric grease.Also check this wiring from this control switch leading into the pod area.Problem could be there.
Old Feb 27, 2015 | 12:46 AM
Thanks, i will try that.
bikedad3
Jul 2, 2015 02:15 AM
chuck1177
Jun 30, 2015 09:52 AM
big_g_squared
Jun 28, 2015 04:17 PM
Fnqrider
May 31, 2015 08:29 AM
bodatiouskid
May 27, 2015 08:33 AM
