01 Trailblazer handlebar control compatibility
Old Feb 28, 2015 | 07:59 AM
parrotheadad@gmail.com's Avatar
Smile 01 Trailblazer handlebar control compatibility
Can a handlebar switch control from a 2002 be used on my 2001. They look very similar but have different part numbers. Do they use the same wiring harness ?
Old Feb 28, 2015 | 09:26 AM
No need to post twice in the regular forums and here also!
Old Mar 1, 2015 | 02:52 PM
Post
The 2001 has the same combo kill / start switch where you lift the switch to start it. I guess what matters then is if the wiring harness assignments are the same.
Old Mar 1, 2015 | 02:59 PM
Then possible it might work as a couple years did have the push up switch,can't remember all the models. And yes,possible wiring can be a little different or even wiring in the connector pins could be switched around. That's why I say always get the correct one for your model,then you won't have to worry or possibly have problems.
salixair
Nov 3, 2015 08:25 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
chewy78
Sep 8, 2015 10:37 AM
Jason Campbell
Sep 7, 2015 02:25 PM
