96 Sportsman 400 wiring
Old Mar 20, 2015 | 02:47 PM
Hilblee's Avatar
Default 96 Sportsman 400 wiring
Im looking for a wiring diagram for a 1996 Sportsman 400. Im rebuilding mine and especially need the wire harness hookups at the steering post. Any help is appreciated.
--Ken
Old Mar 20, 2015 | 03:11 PM
No free manuals with wiring schematic anymore,but here's a cheap one for 5 bucks.DOWNLOAD 1996-1998 Polaris ATV Repair Manual ALL MODELS - Download ...
Old Mar 20, 2015 | 03:16 PM
Hilblee's Avatar
I notice that every manual I see for a 96 sportsman is the newer body style. Mines the older style with the fixed headlight. Does it matter? Especially for wiring?
Old Mar 20, 2015 | 03:27 PM
Shouldn't be any difference as it lists year model even though you have the older style body and head light. They had the newer body style on the the new 96 Sportsman 500. Mainly I believe just to set them apart.
Old Mar 20, 2015 | 03:35 PM
Hilblee's Avatar
Old Mar 20, 2015 | 03:36 PM
Hilblee's Avatar
This is the only example I could find but there should be more wires hooked up that aren't on here.
Old Mar 20, 2015 | 03:38 PM
Plenty more wires are hooked up..
Old Mar 31, 2015 | 10:39 PM
Hilblee's Avatar
Ive got the wiring all back together except for 2 issues. There is 1 white/blue and 1 light purplecolored wire that i cant find where to hook up. I dont know if the light purple is considered purple but its not even close to the color of the 2 purple wires. My other issue is the idiot light wires--which color to which light. Any help appreciated! Thanks
Old Apr 1, 2015 | 03:24 AM
Only white/blue wire that I can think of off hand goes to the ignition coil. Yellow goes to high beam indicator,purple to the reverse indicator(could be the lavender) Green/white to the neutral indicator,purple/black to the low oil light.Should have a small group of brown(ground wires that tie into the indicator lights also. If you still have problems just get the 5 buck manual with the wiring schematic.Can help you in many ways. DOWNLOAD 1996-1998 Polaris ATV Repair Manual ALL MODELS - Download ...
Old Apr 1, 2015 | 09:42 AM
Hilblee's Avatar
Thanks OPT! That ignition coil is the one I forgot about. I'm just gonna hook that light purple wire up to the purple cluster and see what it does.
On the dash lights, there is 4 grounds wired together but 5 lights. Do both of the wires off the oil tank go to the light to provide a ground?
