1983 Honda ATC No Start Help!
I've got a 1983 Honda ATC that doesn't want to start. When you pull the pull cord with choke halfway on for the first few times it seems to try to start like you can here it begin to fire up but won't. After pulling the rope a few times and still no start I pulled the plug and it's soaked on gas. I don't know where to go from here I have cleaned all electrical connections, cleaned the carb, checked plug gap and she still won't fire up. Where do I go from here? Any help would be appreciated thanks!
Don't just try to clean a carb install a carb kit. Plenty of them on ebay.1983 Honda Atc carb kits | eBay Plus make sure the air filter is ok,has fresh fuel. Plus pull the plug,hold the throttle wide open,pull the recoil several times to clean any excess fuel out of the cylinder.
Honda Side by Sides
27
Aug 14, 2015 01:13 AM
