bush Hog TH4400
Old May 15, 2015 | 10:49 AM
Lew Teemley's Avatar
Default bush Hog TH4400
I have a 2009 Bush Hog TH4400. I am lookng for a shop manual. This is a discontinued model and literature is hard to find. I have torn cv boots on the rear axles. I bought a left and right axles. Trying figure out how to remove swing arm to remove the old axle from the hub. Any help appreciated. This is a great machine built tough.
Old May 15, 2015 | 02:57 PM
user493's Avatar
Moto Psycho
I found the operator's manual but not a shop manual. Have you asked the Bush Hog company about getting one? Here's their contact page and link to the owner's manual. Contact Us Bush Hog® Perfomance You Can Count On
Old May 16, 2015 | 05:57 AM
Thanks,
I found the Owner manual, but I need the shop manual. I also need a wiring diagram of the harness. The cooling fan runs all the time, not sure if its supposed to. The motor is a 24hp Honda engine. Not sure if honda uses a thermistor or a temperature switch to control the fan. I have not called a dealer for the manual that may have to be my next step. Any help appreciated. Thanks again.
Old Jan 11, 2016 | 11:50 AM
Jim Marshall's Avatar
Default Bush Hog TH4400 Shop Manual
I have one in pdf form. I will try to hunt it down and post it. The fan that is constantly running is not a cooling fan. It provides constant pressure to the CVT Transmission Houshing so that water can not get in to it. So it always runs.
More later
Old Feb 10, 2020 | 09:13 PM
Agj1224's Avatar
Default Bush hog TH 440 Replacement CV axle.
Anyone looking for a replacement CV axle for the front of a bush hog TH 440. The 06 sportsman 500 HO before 10/06 will work.
Old May 15, 2020 | 04:04 PM
adjef's Avatar
Exclamation Still looking for Bush Hog TH400 wiring diagram... Anybody??
More later
I'm rebuilding a a somewhat scrambled 2007 TH4400 Bush Hog and I really need the wiring harness.... My system is not charging and there is only 1 wire to the regulator?
Very hard to find diagram... Does anybody have one?
Would be very much appreciated.
Many thanks
Andrew
Old Jul 25, 2021 | 08:23 AM
Ford4368's Avatar
So this will work I am having a hard time finding an axle.
Old Jan 3, 2023 | 02:48 PM
trapjohn's Avatar
Default TH4400 rear axle
I tore a boot on one of the rear axles on my 2006 TH4400. The 2 suppliers that I know of for parts for this machine (Messicks and German Bliss) cannot get them axles as they are obsolete. Is there a cross reference to it? The part number is 50041476 for the axle. I would just as soon replace the axle instead of just the boots. Thanks
Old Apr 7, 2023 | 06:23 PM
Dusty utv's Avatar
Yes trapjohn I used the polaris 500 axles on the rear of my bushhog. They appear as they can be used on the front also. I believe alot of the drive axle parts and front strut assembly are all polaris.
Old Apr 9, 2023 | 03:14 PM
trapjohn's Avatar
Thank you! I did end up just getting the boot kits and replacing the boots, but if that happens again I will replace the axle as it is probably about the same price.
