help
Old Jul 16, 2015 | 08:51 PM
1988josh's Avatar
Default help
Need help I have a 99 sport 400 it bogs down when taking off but after u get going it runs great what could cause that.... thanks for yalls help
Old Jul 16, 2015 | 09:43 PM
Loading up from too much fuel in most cases until you have enough rpm and speed to accept the fuel. This usually is from a worn needle and seat or float level off or both.Plus too large of a main jet can do this also,but if stock I'd suspect the carb. If you have to remove a carb install a new carb kit. The kit costs less than an oem needle and seat.Along with the carb don't over look simple things like a dirty air filter. Can do the same thing.Plus here's the fuel section from the manual that can help you along with checking the float arm level. https://www.google.com/url?sa=t&rct=...,d.aWw&cad=rja http://www.ebay.com/itm/CARB-REBUILD-REPAIR-KIT-POLARIS-1998-1999-SPORT-400-2WD-2X4-98-99-/370626988836?hash=item564b170b24&vxp=mtr
