86 moto4 200cc
Old Jul 17, 2015 | 02:13 PM
TheHood's Avatar
Default 86 moto4 200cc
So I'm trying to figure out if this atv is any good. I got it w carb in pieces and no gas tank. Engine turns over, seems like it has compression. I hooked up battery and can push button to start but no spark. Less than 1volt at coil w key on and engine turning over. Am I correct in thinking there should be 12volts from cdi unit to coil? With key on? Or just when turning over? Want to see if it will run on carb cleaner for a couple revs b4 I buy a bunch of parts, oh and I have blocked off intake quite a bit so if it starts it wont be at wot
Old Jul 18, 2015 | 02:42 AM
You only get volts to the coil when the engine is turning on an AC ignition system, and there is no reason it should be 12v. I seem to recall about 7v AC on some bikes. I am not certain the old 200 was AC but most bikes were, until recently, and a lot still are.
Old Jul 18, 2015 | 10:33 AM
TheHood's Avatar
Hey thanks, that helps a lot, I'll do some more checking and post what I find.
Old Jul 22, 2015 | 02:33 PM
jayking232003's Avatar
take a screwdriver and jump the posts on the starter relay, see if there is any difference. Then ignition coil on ebay is like 10.00. I just got one for a 350 for under 10.00. I figured for 10 dollars vs, 35 years old part,,,, I'd get the new one! I'm just saying, Its not gonna hurt your pocket if it doesn't help. There is also the rectifier and see if there are any inline fuses anywhere.
Old Jul 22, 2015 | 11:31 PM
TheHood's Avatar
That's funny I was gonna post that I had bought a coil and was waiting to recieve it. I did have ac pwr at coil from cdi box when cranking so 9.95 and a wait for a new coil. Then I will continue on the rebuild
Old Jul 22, 2015 | 11:42 PM
TheHood's Avatar
Wish I could figure how to add pics, when I try a screen pops up, "Atvconnection says (http)" that's it...
Old Jul 29, 2015 | 01:00 AM
TheHood's Avatar
Ok finally got the coil and had some time to work on it. Still no spark. Feel a bit sheepish cause I found where someone had replaced ground wire bolt to frame w a screw w bolt head and a rubber washer! Cleaned that mess up and voltage dropped ground wire, coil ground and 3 ground wires by headlight... All ok now but, now no voltage at coil wire at all. Guess I need to get a service manual. Do the moto4 service manuals have testing of cdi box, voltage readings, wiring diagrams etc?
Old Jul 30, 2015 | 02:59 PM
Bulgin88's Avatar
Try a new coil or a second hand one off a skidoo or something it well work, your coil might be weak or cracked or it could be the power pack I have had that happen before running one min then gone the next
Old Aug 6, 2015 | 08:29 AM
bvolks's Avatar
My brother's '86 200 Moto4 hasn't started off the electric start for years. It fires up on the first pull with the pull start. Have yo tried it with the pull start or is it like his '89 with electric start only?
https://atvconnection.com/forums/yam...ric-start.html
Old Aug 8, 2015 | 05:49 PM
TheHood's Avatar
Default Still no spark
Got the service manual and ohmed out pickup coil, spec is 196 ohms I get 125 ohms, wondering if this will make a no spark condition. Gonna try to look for ac voltage at pickup coil tonight when cranking.
scman843
Jun 18, 2017 10:21 PM
01ssls1
Sep 22, 2015 06:50 AM
01ssls1
3) General Discussions..
Sep 21, 2015 12:23 PM
QuadCity
Aug 13, 2015 12:58 PM
zach1106
Jul 31, 2015 01:55 AM
