Carb rebuild
Old Jul 24, 2015 | 12:04 PM
GregM's Avatar
Smile Carb rebuild
I have removed the carb and all jets except the needle jet. Does it need to be removed and cleaned in this process? Not seeing much dirt or varnish in carb. It ran ruff before and put some carb cleaner in gas and it helped some. Top end is lacking only around 30. Atv set for a while with little run time before I purchased. 1996 sportsman 500 600 miles. Will check the inline filter after carb finished and installed. Any other suggestions or advise? Thanks
Old Jul 24, 2015 | 12:47 PM
IMO yes the needle jet needs to be removed and cleaned thoroughly since you have the carb off anyway..Not necessary to pull the jet block assy. Plus look closely at the float needle and seat for any shiny spots on the needle sides,wear marks on the inside of the seat. And also the float arm pin for any wear. This can cause floats to stick along with a worn needle and seat. If you have doubts on the needle and seat,just get a carb kit. The float pin is a dealer item doesn't come in the kits or possibly you can find one on ebay.Item#16.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
Old Jul 24, 2015 | 03:57 PM
GregM's Avatar
Smile
I see no indication of wear or dirt or varnish on anything. The rubber is like brand new. I will remove the needle as soon as I figure out how. The manual is not real clear. Take the top out and turn carb on side and remove, that told me a lot. I remember reading something about using an ink pen to remove something, was that it? A flat side has to be in a certain way etc etc.
Thanks
Old Jul 24, 2015 | 03:58 PM
GregM's Avatar
Smile
How do you check the float level, I do not have a guage, can I use something else or do it another way?
Old Jul 24, 2015 | 05:12 PM
This pdf on the fuel system can help on all Polaris carbs whether the VM series or the BST34 or 40. You have the BT34. Shows more into detail and how to set the float level. Plus the main jet holds the needle jet in place. Just tap it out of the jet block.Has a slot in it that goes a certain way to seat it back in the jet block.https://www.google.com/url?sa=t&rct=...,d.aWw&cad=rja
Old Jul 29, 2015 | 09:41 PM
GregM's Avatar
Smile Carb Rebuild
I got the carb back togeather with NO left over parts. I have thre choke & throttle cable back togeather with a little issue. I am now attaching to the rubber boot and will start on the gas lines tomorrow. Thanks for all your help.
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Mar 6, 2018 06:53 AM
kelleycully
Sep 15, 2016 02:57 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
yambam13
Jul 4, 2015 01:49 PM
