Amp Links
Old Apr 10, 2001 | 10:08 AM
cdk's Avatar
cdk
what does everyone think about Amp Links? I have one on my Banshee (it was on it when i got it, so i dont know about a before/after comparison). i am wanting something to keep the front end from jumping up on my blaster all the time. the blaster has a big bore kit on it, a fmf fatty pipe and a power core II silencer, and UNI airfilter with holes in the lid. will the amp link do what i want it to do or should i go with an extended swing arm? anyone have before/after comparisons on the amp links? thanks.
Old Apr 10, 2001 | 12:33 PM
CP's Avatar
CP
I have a friend that used to race his banshee. He used to have an amp link on his machine and said he felt it only made a mild improvement. He also ended up taking the amp link off because the bearing kept going on him (in the amp link) and are expensive to replace.
Old Apr 10, 2001 | 01:34 PM
raptor826's Avatar
The amp link works great on the banshee. It prevents the suspension from compressing under heavy accelartion. I don't think it will help your blaster's front end stay down but it would help the suspension.
Old Apr 10, 2001 | 01:45 PM
rnog's Avatar
Don't waste your money on it, I had one on my banshee and it did not make any difference. It is not only my opinion but that of others who race banshees. You could use that money for other things.
If you wheelie too much, play with the gearing to lower some of the torque, you will have more top speed and less front end lift. Use the money from the amp like to buy a couple of front and rear sprockets so you can find the right gearing for the use you give your blaster.
Old Apr 10, 2001 | 02:28 PM
sAyIt_fmf's Avatar
It's your money...But don't waste it. Not a noticable improvement for all the maintenance it requires. Very loud rollers and increased chain wear are just a few of it's downfalls.
Someone posted this comment:
"It prevents the suspension from compressing under heavy accelartion."
It does far from that statement...It does not stop the suspension from compressing...It keeps the angle of the chain even with the swing arm. For better/consistant power delivery to the ground. In theory eliminating chain lash. But as I mentioned...the difference is questionable.
Just my opinion...so If you like it...Use it. I blew a bearing in the middle of nowhere...I was not pleased..and the chain wrapped around everything..Not fun for $150
salixair
Nov 3, 2015 08:25 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
bigred20653
Oct 2, 2015 10:05 AM
1ArmBandit
Sep 8, 2015 08:59 PM
JakeXBL
Sep 5, 2015 01:08 PM
