Polaris ATV 3 Way Fuel Pet Cock Valve
Old Sep 20, 2015 | 10:41 AM
lgardner61980's Avatar
Default Polaris ATV 3 Way Fuel Pet **** Valve
I have a 1997 Polaris ATV, what position should the 3 way fuel pet **** valve be in to be on?
Old Sep 20, 2015 | 11:04 AM
All the fuel valves are the same way. Straight down is on, to the left is off,straight up is reserve.
Old Sep 20, 2015 | 12:23 PM
Thank You,
I am also getting a limited supply of fuel into the filter and when it does fill I get fuel leaking out of the carb. I idled it up a ways with the **** on the carb. Would that help burn any excess fuel building up in the carb. carb, 3 way fuel valve, and pump has been replaced.
Old Sep 20, 2015 | 12:48 PM
If the carb is leaking it's usually either a worn needle and seat or float level problem. Doesn't matter on how much fuel is being pumped or how much or little the fuel filter shows. Plenty of carb kits on ebay for your model if needed.Plus look over this pdf section on carbs from the service manual. https://www.google.com/url?sa=t&rct=...U2gGlaHJWSIlbA
Old Sep 20, 2015 | 01:32 PM
Thank you for your help, I am an out house mechanic at best but I can muddle through some maintenance issues
Sjrpp
Jun 2, 2019 07:25 AM
MNatv89
Jul 7, 2015 11:36 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
