1991 trx250x stalling
Old Sep 24, 2015 | 10:59 AM
Pehter's Avatar
Default 1991 trx250x stalling
Hi I have a 1991 trx250x that starts up fast and rides good but I'm having a issue at top speed. It gets there and drives good but after a few seconds it starts to stall but if you let go of the throttle it doesn't die but if you hold it the atv will stall and day. Any advice? Its stock but has a white brothers exhaust on it.
Old Sep 27, 2015 | 09:20 PM
LaneWebster's Avatar
Default Simple fix.
How long has it sat. It might need the carb cleaned and a new air filter
Old Sep 27, 2015 | 09:24 PM
Pehter's Avatar
It hasn't been sitting I run it every week or every other week for a good while, I do the oil changes on time and the air filter was changed recent. Also I had someone rebuild and clean the carb, I changed the spark plug, cdi, and the ignition coil (I believe that's what it's called)
Old May 30, 2016 | 10:33 PM
justriding's Avatar
Default might beed adjusting
what do u have the carb adjusted to? could be that i had a 300ex did that all the time i adjusted it and it was fine
Old Sep 3, 2016 | 11:14 PM
Atv mech's Avatar
Default Running out of fuel in carburetor try a larger fuel line.
may need float set to allow more fuel in bowl.. hope this is helpful
Old Sep 4, 2016 | 08:22 PM
papa hogg scoot's Avatar
Loved
Community Favorite
This post is almost an year old....
Old Oct 3, 2024 | 11:00 PM
Ozarkman4wheels's Avatar
Default Gas engines 1o1
Clean the jets in your carburetor, more specifically your main jet. Possible adjust your needle to allow more fuel. If it doesn't want to run at little throttle or pops and backfires clean your pilot jets. In my opinion you cleaning one you'd be a very special kind of person if you didn't go ahead and clean all of them. Or fuel filter or petcock plugged.
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
wendal
Sep 15, 2015 01:50 PM
