2008 700xp Ranger Idle problem
Old Sep 28, 2015 | 01:53 PM
IMLN's Avatar
Default 2008 700xp Ranger Idle problem
It starts great runs around 950 to 975 at idle but will not take gas until it warms up. It will back fire . If you let it set and Idle for 5 to 10 minutes it will take gas and run fine. As long as you don't turn it off and let it set for an hour or so it will do fine.Its just when it cools down. Any help would be great.
Old Sep 28, 2015 | 02:58 PM
If you look at the "sticky" post above this section on 700/800 efi problems it shows that most problems are caused by the thin wiring and connectors, not so much the sensors themselves. On the 700 the t-bap sensor wiring was the one we had the most problems with. Sometimes you can wiggle the wiring and can notice a difference in the way they run or it may even have a bare section on the wiring or soft feeling wires that could be partially melted. This and the connectors themselves. Codes may or may not be thrown. The 700 Ranger was bad about this because the t-bap was on the air tube and wiring went under the bed back into the main harness kinda loosely. Check the wiring on it first for any obvious bare or soft spots,plus also the crank sensor harness that runs under the throttle body that can rub a bare spot on wiring from touching the starter. Best to tie it up if it's touching the engine.Backfiring was another symptom mainly on t-bap wiring issues also. From your description a t-bap harness repair kit may solve the problem and better ones are available than what the dealers have.Only The Best Plus you can remove the t-bap from the air tube and clean it off and see if that helps first.
Old Sep 28, 2015 | 03:32 PM
IMLN's Avatar
Thanks
bzdok1234
30
Feb 23, 2016 01:55 PM
traumajunkie
Jul 5, 2015 03:03 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
D-Hagz
Jul 4, 2015 02:19 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
