2015 polaris 570
Old Sep 30, 2015 | 09:51 AM
anad86.'s Avatar
Default 2015 polaris 570
I have a Polaris 570 thinking of getting 27x10x12 silverback mud tires what size rims can I buy for those tires
Old Sep 30, 2015 | 10:54 AM
TLC's Avatar
TLC
It already has 12" rims why buy another set of rims? The last number is the rim size so you need 12" rims like it already has.
Old Sep 30, 2015 | 11:06 AM
anad86.'s Avatar
one rim has a dent in it and I wanted a different style rim when I know I need a 12 but wasn't sure if that's the only dimension I have to worry about with these tires
Old Sep 30, 2015 | 11:51 AM
TLC's Avatar
TLC
OK, use this chart it explains everything you have to make sure the "Off-Set" is also correct. ATV Tire and Wheel Application Chart : ATV Tires Free Shipping : ATV Wheels : Mud-Throwers.com
If your ATV is not on the chart you can measure your Offset and rim width on your own just to be safe. Your bolt pattern is 4/156
The pic bellow is a 7" wide rim with a 4+3 Offset. To give you the idea.
Old Sep 30, 2015 | 11:55 AM
anad86.'s Avatar
Okay thanks
Old Sep 30, 2015 | 12:55 PM
greg74's Avatar
If you're buying wheels from a website or dealer, they will make sure you get wheels that fit your machine. But yes, its good to know your bolt pattern to know if wheels from another machine will fit your ride. Sometimes a particular bolt pattern is shared by many different models. Like a Grizzly 660 for instance has the same bolt pattern as I believe a King Quad 700, Brute Force 750 and a Honda Rincon. Possibly even more. A chart like TLC posted is useful in showing if your machine shares a bolt pattern and offset with another machine in case you see a good deal on a used set of wheels and tires that may have been on another quad but will fit yours.
Club News and Events
May 28, 2016 08:02 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
Sw00p
Sep 24, 2015 02:50 PM
Sep 22, 2015 10:35 AM
