polaris magnum 1997 6 wheeler
Old Oct 5, 2015 | 05:30 AM
bestball's Avatar
Smile polaris magnum 1997 6 wheeler
Newbie, seems like my limiter is on forward and reverse, Stuttering forward and reverse only the overide butoon doesnt have any effect? Help: Thanks
Old Oct 5, 2015 | 08:47 AM
Just unplug the black wire from the limiter and it should sole the problem. You can have full power in reverse without having to push the over ride button. You may need to push it to engage the awd though. Item #39 is the module. Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse If you don't like having to push the override for awd you can bypass this also as some have done.
"Trace wires from the override button (gray/white & gray/orange) Cut the gray/orange and tape up both ends. Cut the gray/white and tape up the end which goes to the override button. Connect the other end of the gray/white to the red/white (ignition supplied 12v)"
Old Oct 5, 2015 | 09:45 AM
bestball's Avatar
Default Polaris 6 wheeler
thanks for the info great response your awesome. How about bypass for transmission switch as well.
Thanks in advance!!
Old Oct 5, 2015 | 10:10 AM
Here's one way to by pass the gear switch.
Old Oct 5, 2015 | 11:28 AM
bestball's Avatar
Default 6 wheeler
Thankyou once again your awesome. Nice to have someone to lean on! Keep it up!
Old Oct 10, 2015 | 06:34 PM
bestball's Avatar
Default NO power sputers magnum 6 wheeler
Bypassed rev limiter and transmission switch . works great on flat try a hill and it misses changed fuel pump fuel filter plug looks OK . Help
Old Oct 10, 2015 | 06:40 PM
Don't overlook a worn belt or clutch problem that can cause some of this also.
Old Oct 10, 2015 | 06:53 PM
bestball's Avatar
Smile
I will check that tommorow hopefully the belt I have a new one! Thanks for the quick response . Your awesome will let you know if it works.
Old Oct 10, 2015 | 07:03 PM
Guide buttons wear on the front and ramp buttons wear on the rear clutch. Hold one sheath on the rear clutch and turn the other one and letnit slip back. If you hear any grinding or feel roughness, the ramp buttons may need to be replaced.Item #17. Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Worst case ones look like this. Plus if the belt has more than 1 1/2" drop when pulled down from the top,it's worn out.
lonerider856
Oct 13, 2023 03:45 PM
kampswas
Sep 23, 2015 05:05 AM
Schneider
Jul 24, 2015 05:05 PM
colt77
Apr 24, 2001 09:21 AM
YZGUY
Mar 14, 2001 03:51 PM
