What size is the nut on the front sprocket of a raptor
Old Apr 10, 2001 | 05:52 PM
Madmike101's Avatar
The biggest size socket I have is 27mm. What is the size of the nut and is it reverse or normal threaded. If there is another technique to remove the nut I am open to suggestions. I know it has to be close to 32mm.
Old Apr 10, 2001 | 07:18 PM
Zoinks!!!'s Avatar
Its been a while since I messed with the sprocket but if I remember correctly I used a 1 1/4 in wrench. Not sure though just know that it is a pain in the a$$!
Old Apr 10, 2001 | 11:46 PM
RoadKillJoe's Avatar
32mm or 1 1/4" socket will work. My 1 1/4" actually fits better than the 32mm that I bought.
Old Apr 10, 2001 | 11:59 PM
Raptorrider2001's Avatar
Yep, 32mm or 1 1/4" and the the threads are not reveresed.
Old Apr 11, 2001 | 01:10 AM
pairof98s's Avatar
Use the 1-1/4" socket with an air impact. If you try to do it manually, the bike will roll as you try to loosen the nut. You'll love the 12t sprocket compared to the stock one.
Old Apr 11, 2001 | 04:35 PM
Madmike101's Avatar
Thanks for the input guys! I took a 1 1/4 socket 6 inch extension and a 20 inch breaker bar and it broke loose. Poped in the new sprocket and tightened the chain. Works great, but I am going to have to cut out a link or get another chain before the summer is over. I am definitly predicting that I will need a new chain soon.
JackTheKing
Jul 14, 2015 09:09 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
jettman
Jul 6, 2015 12:16 PM
yambam13
Jul 4, 2015 01:49 PM
Mphillips
Jul 2, 2015 07:20 PM
