2013 Polaris 500 HO
Old Oct 24, 2015 | 09:09 PM
Ronj1977's Avatar
Default 2013 Polaris 500 HO
I recently purchased a 2013 Polaris 500 HO it appears looking from the back that one side is higher than the other front looks straight but rear seems tilted slightly is this normal ? I measured the height from the ground up middle of rear tire to plastics and there is a 1.5 inch difference.
Old Oct 25, 2015 | 01:20 PM
First off,may sound silly,but check that tire pressure is the same. This can affect the height. If tire pressure is at say 5 psi front and rear,check that the rear shocks are adjusted the same. Also check if the lower looking side rear spring is leaning inward,touching the shock body itself. This indicates a weak spring. Try adjusting the shocks up and see if this helps. If it doesn't may have a blown shock or weak spring on that side.
Old Oct 25, 2015 | 03:41 PM
Ronj1977's Avatar
Here is a pic of the side that is low
Old Oct 25, 2015 | 03:44 PM
Ronj1977's Avatar
Hopefully a better pic
Old Oct 25, 2015 | 04:07 PM
Just set the shock adjusters up and see if it helps first.
Old Oct 25, 2015 | 05:14 PM
Ronj1977's Avatar
How do you do that
Old Oct 25, 2015 | 05:44 PM
In your tool pouch is a spanner that adjusts the shock spring tension stiffer.The adjuster collar is right at the bottom of the springs.
Old Oct 26, 2015 | 02:13 PM
user493's Avatar
Moto Psycho
I've had some tool kits that included the shock spanner and some that didn't. I bought one at a nearby motorcycle shop.
P.S. It was always easier for me to pull the wheels off and have more room for the wrench to turn.
Old Oct 28, 2015 | 08:04 AM
Ronj1977's Avatar
It looks like there booth set to the highest setting I used a set of locking pliers and twisted the hi side down one didn't seem to mak a difference in height
Old Oct 28, 2015 | 09:15 AM
If everything else looks ok in the rear suspension then probably a blown shock.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
