1998 scranbler 400 4x4 not working
Old Oct 30, 2015 | 09:25 AM
bigpollyboy's Avatar
Question 1998 scranbler 400 4x4 not working
OK.....I took apart the shifter switch and cleaned it, also replaced the two rubber O-rings. the switch appears to be functioning but the 4x4 still will no operated. I also moved the gray/white wire from the switch to a red/white post with negative results ???
Old Oct 30, 2015 | 10:05 AM
One other thing to try is making a common ground connection for the both the hub coils as many have done on intermittent awd problems. Try this and see if awd works.
Old Oct 30, 2015 | 10:22 AM
Mine is different and I don't seem to have the two white connectors that in the video
Old Oct 30, 2015 | 10:47 AM
You have two brown wire coming from the strut coils leading up under the front panel. They tie in somewhere! Just cut these two wires,tie all 4 wires(wires from coils and ones you cut) to a larger wire and ground it either to the main ground(coil mount) or to the frame.
Old Oct 30, 2015 | 10:56 AM
I did locate the hub coil wires (they are really thin) there is a brown/white and a gray for each side....
Old Oct 30, 2015 | 11:15 AM
Yes you have the brown/white wire instead of the solid brown as in earlier models. One other thing I forgot is you can trace the awd button gray wire(the main wire that jumps from the shifter switch)and hook it to the red/white terminal and then see if the awd button lights up when pushed and awd funtion is good. I think that's how some have bypassed the shift switch entirely..
Old Oct 30, 2015 | 11:27 AM
I have a gray, gray/white and a brown coming from the shifter switch....I did move the solid gray to a red/white post and the AWD light did NOT turn on. ?
Old Oct 30, 2015 | 11:30 AM
Oh.. I want to move the AWD button gray to a red post not the switch gray....let me try that before I cut wires
Old Oct 30, 2015 | 11:34 AM
I moved the AWD button gray wire to the red/white post....AWD light came on with the key (even while in neutral) but still no four wheel drive.
Old Oct 30, 2015 | 11:38 AM
Hmmmm.. Out of the shifter switch try the gray/white wire to the red/white and see if it powers up the awd button.. I'm still trying to remember how people did this with out replacing this high $ switch..
