1998 scranbler 400 4x4 not working
OK.....I took apart the shifter switch and cleaned it, also replaced the two rubber O-rings. the switch appears to be functioning but the 4x4 still will no operated. I also moved the gray/white wire from the switch to a red/white post with negative results ???
Yes you have the brown/white wire instead of the solid brown as in earlier models. One other thing I forgot is you can trace the awd button gray wire(the main wire that jumps from the shifter switch)and hook it to the red/white terminal and then see if the awd button lights up when pushed and awd funtion is good. I think that's how some have bypassed the shift switch entirely..
