06 kodiak 450 leaking oil from front diff and driveshaft
Old Nov 21, 2015 | 09:15 PM
danielbui's Avatar
Default 06 kodiak 450 leaking oil from front diff and driveshaft
hi guys i have an 06 kodiak 450 and ive been doing maintenance on it before i put on my snow plow for the winter. after my oil change along with changing the front diff and rear diff oil i noticed that theres a leak coming from where the drive shaft connects to the front diff. when i changed the front diff oil, there were little to no oil there. so how would i repair this leak.
bad seal? or do i have to repair the whole diff or drive shaft? im a noob at this and this is my first time.
if its the seal how would i remove the drive shaft to replace the seal? also there is a lot of play when i move it.
drive shaft connecting to the front diff where the leak is
Old Nov 23, 2015 | 08:12 AM
TLC's Avatar
TLC
Its the seal. Common problem on Yamahas the good news is the seals do not cost much and it not a hard job to change. Here is one of many videos on changing them. Bottom vid is a axle seal.
Old Nov 23, 2015 | 08:44 AM
danielbui's Avatar
Ok good. I bought the seal cost about 20bucks. so it's the seal even though there's a lot of play when I tugged on the drive shaft? Thanks for your reply
How to Remove ATV Differential Seal - YouTube
How To Replace ATV Differential Seal - YouTube
660 GRIZZLY REAR SEAL REPLACEMENT - YouTube
Ben Freed
Ask the Editor
Nov 23, 2015 05:59 PM
twin051302
Nov 20, 2015 05:08 AM
Maxoubasou
Nov 17, 2015 01:14 PM
littleboots
Nov 16, 2015 09:31 PM
