09 sportsman 500efi broken isolator mount
Old Nov 23, 2015 | 10:20 AM
Ipmcelroy's Avatar
Default 09 sportsman 500efi broken isolator mount
Anyone know if the rear two isolator mounts are usable-interchangable for the front engine mounts. The only difference by eye i could see between them was the rear ones have a diff. Thread on one side which screws into motor case. I could care less about that. My front lower isolator bolt delaminated from the rubber puck. I have extra good rear isolators from a spare 98 bottom end. Just want to swap 1 to front.
Old Nov 23, 2015 | 05:03 PM
One part number difference between the two mounts probably because of the thread pitch difference if there is any. Not sure but think the rear mounts are a tad thinner than the front isolator mounts,but don't think that would cause that much concern..I'd go for it rather than wait for one. Just make sure you have a nut that will fit the bottom threads if the thread pitch is different.
Old Nov 24, 2015 | 12:21 PM
Ipmcelroy's Avatar
Yes you are right the rear isolator mounts are a tad thinner, only about 25-30 thou. I'll just make that up with a washer on bottom. Thanks!
svahle
Aug 16, 2017 01:33 PM
danielbui
Nov 23, 2015 08:44 AM
Polaris Side by Sides
Nov 22, 2015 02:27 PM
twin051302
Nov 20, 2015 05:08 AM
