1996 Polaris explorer 400
Old Nov 24, 2015 | 11:35 AM
Josh996's Avatar
Default 1996 Polaris explorer 400
Hi I have a explorer 400 2 stroke atv I'm having trouble with it running, the atv will start and idle fine but when I put it in gear and give it gas it runs okay until about half throttle ,then it make a low bogging noise and eventually shuts off I have took carburetor apart and cleaned it it helped the bogging noise a lil but didn't fix the issue im rly stumped on this ,any ideas
Old Nov 24, 2015 | 01:15 PM
Pull the black wire from the reverse limiter and see if that makes any difference. They can short out and start limiting in forward range also. Located behind the oil tank and wire runs to the circuit board located on the left side under the fuel tank plastic.Item#32.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
Old Nov 25, 2015 | 01:10 PM
Josh996's Avatar
Okay I will try that this weekend and see if that works thank you.
tastyatv
May 28, 2023 11:11 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
spark1051
Utility ATVs
Sep 4, 2015 07:58 PM
Adrian Turner
Aug 30, 2015 04:08 PM
GirlsCan2
Aug 27, 2015 02:58 PM
