06 yamaha kodiak no spark
Old Nov 26, 2015 | 07:35 PM
Laycox82's Avatar
Default 06 yamaha kodiak no spark
Hey guys new to this site. I got a 06 yamaha kodiak with no spark. Story is i went out this morning and started it it fired right up and ran no problem. So i was gonna use the quad to boost the ride on mower so i could move it. Anyways i grab the cables put the 2 ends on the floor and was hooking up the other ends to the quad battery. As soon as i hooked up the positive cable the quad died and now it wont start. Im assuming it shorted out. Any ideas what the problem is?
Thanks guys
Old Nov 27, 2015 | 03:00 AM
By "won't start" do you mean it is completely dead, no starter, lights etc, or just won't fire up and run when the starter is turning? If it is dead, check the battery terminals are clean and tight, and the main 30 amp fuse on top of the solenoid.
Old Nov 27, 2015 | 09:56 AM
Laycox82's Avatar
Just wont fire. Turns over no problem got lights etc just no spark.
Old Nov 27, 2015 | 10:12 AM
TLC's Avatar
TLC
Try this its a 348cc same motor as your 386cc but it was stroked out from a 64.5mm to a 71.5 mm ,both have the same 83mm bore.
Old Nov 28, 2015 | 03:13 AM
I thought all Kodiaks had a water cooled engine. It could be that pick up coil, but it could be the plug, the ignition coil, CDI, voltage regulator, or a wiring fault. Check the wiring, and if that seems to be OK, get a manual and go through the electrical checks listed in it.
ultangler
Nov 30, 2024 01:35 AM
mickelson23
Sep 29, 2015 12:28 PM
DMIMAGE
ATV Expeditions
Sep 20, 2015 06:56 AM
Sep 17, 2015 03:06 AM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
