Hisun 700 R light in cluster
Hi!!!
I'm having a problem, wen I turn the key on the R in cluster is on and stays on wen ridding. Now my problem is that it won't go over 20mph it will cut off on the rev limiter any ideas what could cause this ???
Thanks
Thanks
The problem is, the machine thinks it's in reverse and is hitting the rev limiter.
If memory serves, you'll need to remove the air box assembly and look farther down on the engine/transmission case and you should see the revrse wiring switch. You either need to clean and tighten this connection or remove this wire and attach it to a known good ground. This should fix your problem.
[QUOTE=4getful2;3309977]The problem is, the machine thinks it's in reverse and is hitting the rev limiter.
If memory serves, you'll need to remove the air box assembly and look farther down on the engine/transmission case and you should see the revrse wiring switch. You either need to clean and tighten this connection or remove this wire and attach it to a known good ground. This should fix your problem.[/QUOTE
[QUOTE=88king;3309979]
I unplugged it and now it works great.
