Hisun 700 R light in cluster
Old Dec 13, 2015 | 06:44 AM
88king's Avatar
Default Hisun 700 R light in cluster
Hi!!!
I'm having a problem, wen I turn the key on the R in cluster is on and stays on wen ridding. Now my problem is that it won't go over 20mph it will cut off on the rev limiter any ideas what could cause this ???
Thanks
Old Dec 17, 2015 | 05:50 PM
4getful2's Avatar
The problem is, the machine thinks it's in reverse and is hitting the rev limiter.
If memory serves, you'll need to remove the air box assembly and look farther down on the engine/transmission case and you should see the revrse wiring switch. You either need to clean and tighten this connection or remove this wire and attach it to a known good ground. This should fix your problem.
Old Dec 17, 2015 | 06:28 PM
88king's Avatar
Default Already did that. Dint work took a relay under the hood. I unplugge
[QUOTE=4getful2;3309977]The problem is, the machine thinks it's in reverse and is hitting the rev limiter.
If memory serves, you'll need to remove the air box assembly and look farther down on the engine/transmission case and you should see the revrse wiring switch. You either need to clean and tighten this connection or remove this wire and attach it to a known good ground. This should fix your problem.[/QUOTE
Old Dec 17, 2015 | 06:29 PM
88king's Avatar
[QUOTE=88king;3309979]
I unplugged it and now it works great.
Furby01
Mar 14, 2017 04:25 PM
fhorta
Dec 17, 2015 07:53 AM
TRXWOLV
Dec 16, 2015 07:39 AM
Espo720
Dec 3, 2015 02:13 PM
kpeac17
Nov 18, 2015 02:16 AM
