Rear brake caliper on 98 sportsman trans
Old Dec 27, 2015 | 06:26 PM
Ipmcelroy's Avatar
Default Rear brake caliper on 98 sportsman trans
So i took a 98 sportsman that had the trans from a 1996. Swapped out the trans with another grom a 1997. I thought the only difference on them was that there was a nut that actually held the rotor down on the trans shaft. Well i guess they changed the calipers. The bolt pattern on them is about a 1/2" diff. Etc. Has anyone tried to use a 1996 rear caliper on a 1998-02 transmission? Im sure an adapter plate could be made to make it work. Otherwise have to buy a whole new caliper,rear resorvoir,w hydraul. Cyl etc. I do have the rear caliper and cylinder but they are pretty. Tired only one caliper cylinder will push out
Old Dec 28, 2015 | 06:50 AM
Problem with an adapter plate is that you couldn't get the rotor and caliper lined up properly without eating up pads,plus have to crossbreed a manual emergency brake type caliper with a hydraulic emergency brake system. 96 and 97 were similar on calipers,rotors changed on the 97 models. 98 was a completely different system. Basically it's best on whatever transmission you have to scavenge the correct brake parts,caliper,brake pedal,etc from salvage places,ebay,etc.
Old Dec 28, 2015 | 10:23 AM
TLC's Avatar
TLC
My dads 97 has a mechanical/cable rear foot brake and in 98 they switched to a hydraulic foot brake.
John in OH
Dec 14, 2015 07:32 PM
wamulass
Dec 6, 2015 07:16 AM
mikesjunk
Dec 5, 2015 04:07 PM
Garfoot
2) Chassis problems..
Dec 5, 2015 12:43 PM
500sportsman2002
Nov 29, 2015 09:03 PM
