Arctic Cat Sway Bar kit pn 0436-744
Old Jan 7, 2016 | 03:33 PM
hydrex's Avatar
Default Arctic Cat Sway Bar kit pn 0436-744
For you folks with Arctic Cats that don't have a rear sway bar. If your Kitty seems overly tippy on the tight corners, especially if you have a lift, check out this kit. Yes, even if you have an older non IRS model, it will work. My 2001 was the last year for straight rear axle, it took 1.5 hours to install. Mount the bushing brackets on the frame just under the air box. End links mount to fore and aft trailing arms. Day and night difference. A couple pictures, it's pretty self explanatory, use torque specs in the guide that comes with kit. Probably could make this work on other non AC bikes.
Attached Thumbnails Arctic Cat Sway Bar kit pn 0436-744-p1010576.jpg   Arctic Cat Sway Bar kit pn 0436-744-p1010577.jpg   Arctic Cat Sway Bar kit pn 0436-744-p1010578.jpg
Jan 10, 2016 05:05 PM
Danielpschlier
Jan 8, 2016 09:53 AM
Danielpschlier
Jan 7, 2016 09:39 AM
Michael Wood
2) Chassis problems..
Jan 5, 2016 01:45 PM
Tomrob
Jan 5, 2016 09:51 AM
