Quadrunner 160 Reverse Problem
Old Jan 24, 2016 | 12:06 PM
Tyus4's Avatar
Default Quadrunner 160 Reverse Problem
Hello, I tried doing a search but had no luck. I have a quadrunner 160. When I try to put it in reverse, the reverse light goes on but when you give it gas, there is a short grind and it slips out of gear. Don't have any experience with these. Just wondering what can I check out? Thanks
Old Jan 25, 2016 | 04:16 AM
If it has cable operated gear shift, the cables can stretch and not move the lever on the gearbox far enough. You have to adjust the cable so it goes in reverse, but don't overdo it or it won't go in forward properly.
Old Feb 1, 2016 | 12:13 PM
Tyus4's Avatar
Thanks, Went and adjusted the 2 nuts on the end of the cable and it worked.
Mekronid
Jan 16, 2016 07:09 AM
viponderosa
Dec 28, 2015 05:34 PM
viponderosa
Ask the Editor
Dec 27, 2015 12:48 PM
