1991 fourtrax 300, front wheels seizes up
Old Jan 31, 2016 | 01:31 PM
smacktrot's Avatar
Question 1991 fourtrax 300, front wheels seizes up
Different times the left or right front wheel will seize up, the other three wheels work and one of the front wheels will slide. I put the bike in reverse, give her a shot then the seized wheel and the other three wheels turn, put back to forward until it happens again.
I removed the front brake shoes, bike has front brake drums and they were garbage and it still does the same thing.
any ideas?
Old Feb 1, 2016 | 02:23 PM
Fasteratv's Avatar
any ideas?
You are saying that you have the brake shoes removed on the front...both sides? If the shoes are removed, then you either have a bad wheel bearing, axle bearing, or something wrong in the front diff. Is this a 4WD?
Old Feb 1, 2016 | 07:18 PM
smacktrot's Avatar
it is 4wd
Old Feb 1, 2016 | 07:25 PM
Fasteratv's Avatar
Then you either have a bad wheel bearing, axle bearing, or something wrong in the front diff.
GamMattic
Feb 2, 2016 11:00 PM
Jake1860
Jan 31, 2016 06:12 AM
gearhead1985
Jan 27, 2016 09:02 PM
topfli8979
Jan 19, 2016 03:49 PM
79hugger
Jan 3, 2016 04:11 AM
