What causing a ATV to no longer spark?
Old Feb 10, 2016 | 09:08 AM
Kazjag500's Avatar
Ride it like you stole it
Default What causing a ATV to no longer spark?
I have a ATV and it was running fine one minute, then the next minute, it stopped working! I have absoloutly no idea what happened to it but all of a sudden it stopped sparking, I need help as soon as possible. What can I check to see if that's the problem. THANkS!!
Old Feb 10, 2016 | 09:13 AM
Big600twin's Avatar
Year, make, model??
Any number of things.. Could be something as simple as a fouled plug,shorted out plug cap,bare spot in the coil wire,shorted pick up coil,main stator short,shorted cdi module or even a faulty kill circuit that includes the cdi,ignition switch,left control switch or associated wiring. What year and model do you have? Best to have a service manual that can help you track down the problem..
Old Feb 10, 2016 | 09:14 AM
Kazjag500's Avatar
2007 Kazuma Jaguar. But it was running perfect last week. Then it stopped. But it is the same as Polairs. Almost the same wiring diagram.
Old Feb 10, 2016 | 09:16 AM
Moderators should redirect this to the Chinese section as those guys over there can help you best. Not the same as Polaris,but could be similar as many small quads share a basic engine style,but wiring specs,etc would be different.. From what I've found it may be made by Fugi,but best to try to locate a service manual.
Old Feb 10, 2016 | 09:18 AM
Kazjag500's Avatar
Old Polaris Tech:
Can you please message me privately? I need help solving this and I can get more information there. Thanks!
Old Feb 10, 2016 | 09:26 AM
Kazjag500's Avatar
It is a 500CC ATv. And I am pretty sure this is the same for Chinese and Name branded ATV:
Would you be able to name EVERYTHING involved in the ignition process for a ATV?!?!
This is so I can rule out all possible problems, we have tested the Stator for a resistance test and it was reading around 11 Omhs. Not too sure if that is okay, but I would need to know everything that is involved in the ignition process on a ATV
Thanks.
Old Feb 10, 2016 | 09:32 AM
I just did in my first post about ignition.. Again looking at pics of this engine looks like a Fugi engine or a Chinese clone of one. Again best to find the actual service manual that has the correct specs and trouble shooting guides.
Old Feb 10, 2016 | 09:33 AM
Kazjag500's Avatar
Where is your first post about ignition?!?!
Old Feb 10, 2016 | 09:35 AM
scootergptx's Avatar
Supersock
Hired Gun!
I have moved this to the Chinese section.
