2015 Arctic cat 500
Old Feb 24, 2016 | 09:18 PM
Steven Bandemer's Avatar
Default 2015 Arctic cat 500
So the machine is brand new - got a good deal on last year's model... I plan on letting the warranty run out and get 500-1000 miles on it.
I was wondering about some simple easy mods to help boost some power - I know so much of the time there are restrictions that are not ussaly hard to fix.....if I but it in 4 wheel lock, stop in a 10 inchs of snow it bogs pretty good for 2-3 seconds then takes off. Just wondering what people have been doing
Old Feb 25, 2016 | 09:32 AM
Zrock's Avatar
Super Quad Patrol
You running in low gear? i found mine woke up after about 1000-2000 km on it..
Old Feb 25, 2016 | 09:45 AM
greg74's Avatar
Maybe the performance will get better once its broken in as Zrock is implying. There are little things you can do that don't cost a lot of money like putting in a different plug or air filter than stock. It simply might be some sort of factory limiter in diff-lock as well. Like a reverse limiter, which I have always hated. Putting the machine in 4x4 should override any limiter as it should be assumed that you need full power.
Old Feb 26, 2016 | 08:16 AM
Alright guys thanks! i appreciate the input and ill look into a better plug and air filter
The machine is fun as can be, went threw some heavy deep snow! Thing is really awesome! And ive heard that about break in period - i guess ill have to wait and see!
Old Feb 26, 2016 | 03:41 PM
Bratman2's Avatar
The best mod you can most likely make would be have the sheaves machined and the fixed plate welded. Some one like "Airdam" or "Papa Slap" who specializes in these CVT type drives. They can machine the faces of the sheaves so the belt drops lower on take off giving you a lower geared start. Cut the fixed plate, roll the lip in some and weld will cause the weights to force the plates closer together on top end and give you a slightly higher gear ratio.
Old Mar 20, 2016 | 07:27 PM
steve c's Avatar
Default Arctic Cat 2015
Thanks for all the good comments. I am looking at buying a 2015 Arctic Cat 500 also.
Dirtrider74
Jul 7, 2016 12:50 PM
Kazjag500
1) Engine problems..
Feb 17, 2016 09:41 AM
old polaris tech
Feb 4, 2016 04:40 PM
