Help
Old Feb 29, 2016 | 04:42 PM
Harley05's Avatar
Default Help
Any suggestions was riding my Arctic cat yesterday run perfect left it in the backyard for a while went to get back on it cranked up find put it in reverse and it sounded like gears were cranking put it in forward the same thing happens please help
Old Mar 1, 2016 | 06:59 AM
scootergptx's Avatar
Supersock
Hired Gun!
Moved this over to the Arctic Cat section, you should get more replies here.
Any leaks from the transmission that you noticed?
Old Mar 1, 2016 | 10:15 AM
Fasteratv's Avatar
When you started it back up the second time, did you use the choke/have the choke on when you placed the ATV in gear? Idling too high possibly? That will cause them to grind. Have you checked the oil level?
Old Mar 2, 2016 | 10:11 AM
Alex G.'s Avatar
is it like it's inbetween gears continuously? As in, does it all the time? or does it clunk into gear afew a few seconds?
Old Mar 2, 2016 | 10:24 AM
Harley05's Avatar
Default Hey
No this was the first time that it ever done this and I have noticed that it takes a second when I go from neutral too low for it to go in gear I did notice also that it would not go into high gear my choke was find it cranks up and Idles perfect when I was able to get it in gear it sounded like gears were slipingthanks you guys for all your help
