Trail Boss 330 electrical issue
Old Mar 3, 2016 | 07:43 AM
arc burn's Avatar
Default Trail Boss 330 electrical issue
I believe its a 93 trail boss 330,battery is good,power coming thru fusible link near the solenoid up to the ECM,when you turn the key on the headlights (with the switch on) will light up and go out instantly,turn key off and back on same thing,machine will not start,has no indicator lights working,it has the "Sure power" ECM if it matters.Thanks for any help
Old Mar 3, 2016 | 07:51 AM
I guess you mean a 2003 Trail Boss 330. 330 was an oddball as it did have an updated ecm,but not silver colored and not sure it's US made. Still sounds like an ecm problem. I've had to replace multiple ecms on the same machines,so having a replacement go out(if you've already replaced one) isn't unusual.Item #18. Note the updated part number.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Plus they're not cheap.Polaris 03 04 Magnum Trail Boss Electronic Control Module ECM 4010944 New | eBay
Old Mar 3, 2016 | 08:00 AM
arc burn's Avatar
Yes,03' and thank you for the quick reply,i've never replaced the ECM,just fixing for someone else and have yet to come across an issue like this.Was also wondering about the fusible link,have 12+v on both sides but is it possible to "lose" power under load if it's weak or will it just blow altogether? Again,Thanks
Old Mar 3, 2016 | 08:10 AM
Fusible link will usually just blow.If you have 12 volts on each side it's still good and transmitting power. It's not like the old thermal circuit breakers that could trip and reset. Ecm failures were common on these machines,more so on the 2004/2005 Sportsman 500s and 700s. The 330 ecms imo should have been on the original ecm recall also,but unfortunately weren't. Here's the original recall list on ecms.Polaris Industries Expands Recall of ATVs Due to Fire Hazard | CPSC.gov
Old Mar 3, 2016 | 08:15 AM
arc burn's Avatar
I was told it was early 2000's but i believe it's later,ecm shows a part# of 4011831 which would put it at late 2000's no? how do you read the VIN #?
Old Mar 3, 2016 | 08:19 AM
Look on the right side(facing the front) on the lower frame behind the a-arm. Has a 17 digit vin#. 10th digit is the year model.Plus if you still have the sticker(engine serial number) on the recoil starter,the first two digits is the year model.
https://www.google.com/url?sa=t&rct=...kCP4OVyEDZrhKw
2005 and later models used this silver Sure Power module.http://www.ebay.com/itm/Polaris-Trai...RVpCbI&vxp=mtr
Old Mar 14, 2016 | 01:56 PM
arc burn's Avatar
Update-
New OEM ecm and still same problem,took kill switch apart to clean and the contacts and spring and ball(assuming 1 ball) fell out,now to figure that damn thing out? all the schematics i'm seeing just show the whole switch assembly.
Old Mar 14, 2016 | 03:00 PM
Once you take the kill switch apart you can't hardly ever get it back right again with the ball bearing and the small brass plates flying out. No schematic or repair guides for these. Along with ecms,yes left control switches can short out,get dirt/moisture in the contacts and shut off power to the dash also.. Forgot to mention that also.If you can't get it back together right,best to just get another one. Plus depending on build date,this 330 (if it is a 2003 model) has two different control switches. That where the 17 digit vin# will help if you can get enough info. You can call a local dealer if not sure and they can pull up the build date. Item #10 on the parts break down for the switch numbers.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
Old Mar 19, 2016 | 12:43 PM
arc burn's Avatar
New kill switch,same problem,if lights are in "on" position when you turn the ignition on they will flash once or twice quickly then cut out.
Old Mar 19, 2016 | 01:18 PM
arc burn's Avatar
Unplugged CDI box? black box right above ECM and now have all lights and turns over,obviously doesnt start but lose everything if you plug it back in,got a short somewere in that area.
