2004 honda recon problems HELP
Compression, check. Spark, dont know how to check. valves, will check. sprayed carb cleaner in carb to act as starting fluid, nothing. Am going to clean carb again. could it be that i got to much air for to long and blew the bike up? i could run it for 5 minutes, then it would die for 10 and start again. now it wont start at all.
To check for a spark, take the plug out, refit the plug cap, lay the plug on the head and spin the engine over with ignition on. If you get sparks at the electrode, the problem is probably compression, or the carb not clean.
^^^^^Pretty sharp
Alot of folks don't know this.....
