help! 2004 rubicon no fire
Old Mar 8, 2016 | 10:47 AM
carson_sikes00's Avatar
Default help! 2004 rubicon no fire
ok a few weeks ago i bought a 04 rubicon 500 4x4 with only 1173 miles on it for only 1200 this is a very clean atv. so ive tested the coil regulator etc i took the stator out and bench tested it and it tested good put it back in and its not putting any volts out so i think its bad but my dad thinks it still may be something esle anything else i need to check before i order a 150$ stator thanks
Old Mar 9, 2016 | 06:37 AM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
I'm moving this over to the Honda section, you'll get more answers there.
Old Mar 9, 2016 | 10:54 AM
Fasteratv's Avatar
Has it ran since you have owned it? In regards to the stator, did you check the resistance between the windings.....and then resistance to ground...on each leg of the windings? Have you checked the handle bar kill switch, ( installed a new plug...right ) checked fuses and wiring? It may or may not be the stator. Could be the CDI, but one must first prove that everything else is good prior to purchasing a CDI.
jba
Sep 25, 2016 02:45 PM
Feb 17, 2016 06:02 AM
Feb 11, 2016 01:28 PM
