02 400ex HELP! ASAP
Old Apr 10, 2016 | 05:27 PM
WalterTalt's Avatar
Daily Rider
Exclamation 02 400ex HELP! ASAP
Ok so i have a 2002 400ex it has a big gun exhaust thats all suposedly it has a jet kit but after it came out of the shop the jets look the same as they did when the quad went in to the shop
Anyway cutting to the problems here is a list
1. in neutral the quad revs fine BUT it does not hit rev limiter the normal rev limiter should be budadadadadad mine is buda......buda...........buda.......buda
2. When in first gear the quad will not hit high rpms when you get in to high rpms it seems like the quad is turning itself off until you release the throtle but it will not go into high rpms its almost like if you were in high rpms and then you toggled the kill switch its the same noise and everything
any help would be appreciated and if any one has the jet settings for all the jets that would be great like for every single jet how should it be configured?
how many turns for the main pilot air fuel all of them!
Thanks
IF YOU NEED A VIDEO TO UNDERSTAND I WILL MAKE A YOUTUBE VID
Old Apr 11, 2016 | 04:11 AM
bengear90's Avatar
Something must be done improperly with that neutral sound. Do you personally know the experience of that shop? Sure some experts will chime in, better if you have that video here.
Old Apr 11, 2016 | 09:01 AM
Swerve400EX's Avatar
Cross Country Rider
From my experience its your carb. Your top end jet is the incorrect size or its severely clogged.
Old Apr 11, 2016 | 01:28 PM
WalterTalt's Avatar
Daily Rider
i will post a video asap and swereve400ex which jet though the tallest one the one that has the needle in between the one that goes down into the bowl? or the other one next to it and thanks!
Old Apr 11, 2016 | 01:31 PM
WalterTalt's Avatar
Daily Rider
and bengear90 the shop is trash they stole parts off of it while it was sitting there and put faulty parts in it came out with more problems than it went in with they also rode the **** out off it and blew my rear shock and melted my plastics a bit they also charged a massive storage amount when they said they wouldnt
Old Apr 11, 2016 | 01:49 PM
Cross Country Rider
The jet that you need to look at is the main jet!
Old Apr 11, 2016 | 04:07 PM
WalterTalt's Avatar
Daily Rider
Old Apr 11, 2016 | 04:19 PM
Cross Country Rider
No Problem!!
Old Apr 14, 2016 | 08:47 PM
YvettesSherpa's Avatar
Also check the black plastic valve on the side of the carb.
Old Apr 18, 2016 | 01:58 PM
Chris.400's Avatar
I say get a new main jet, a 155 worked perfect for my 400ex with a sparks exhaust. but for a big gun, i would say a 152.
etstern
Apr 11, 2016 04:32 PM
winedude
Mar 10, 2016 03:13 PM
Whitelx1
Feb 25, 2016 04:57 PM
Luke Sandiefer
Sport Quads
Feb 22, 2016 06:48 PM
HerpDerp1919
Feb 16, 2016 12:39 PM
