will 26x12 tires fit new SP570?
Old May 4, 2016 | 03:33 PM
RticKwad's Avatar
Runs Stealth!
Default will 26x12 tires fit new SP570?
I have a new wheel kit never used for Yamaha Grizzly. The bolt pattern is different so can't use on my new 2016 SP570. I can get a new set of nice rims for under $300. Specing them out I was asked if the 12" would fit the new SP since they don't the XPs per his understanding.
Does anyone know?
Thanks,
R'
Old May 4, 2016 | 03:35 PM
RticKwad's Avatar
Runs Stealth!
this wheel kit is the BigHorn originals on Badland rims (12x7)
26x9x12 front
26X12x12 rear
Old May 5, 2016 | 04:17 AM
switzomatic's Avatar
Had 27's on my wife's. Had to crank the shocks for clearance but they fit.
Old May 5, 2016 | 07:42 AM
RticKwad's Avatar
Runs Stealth!
Thanks Switz, but the scrutiny I had was regarding 12" 's 14". I know my former 2008 SP800 could support both but there seems to be some differences in these new models SP and XP. Trying to get to the ground truth I want to add these Big Horns to my bike.
Old May 5, 2016 | 09:47 AM
Doesn't the 570 come with 12" rims? If so, you won't have problems with 14" rims if the bolt pattern is the same. You run into problems with the brakes if you try to go from 14 to 12 inch rims. Judging from my son's Scrambler I think you'll have room for the slightly wider tires too. They moved a lot of the front suspension inside the rim. Ask your dealer to be sure.
Old May 5, 2016 | 09:54 AM
Polaris' website shows the camo 570 in two versions. EPS and EPS SP. The regular EPS model comes with 12" rims. The SP comes with 14" rims. So, I think your's has 12". Just check the size on the side of the tire. If you want to go with 14" rims you should be okay as long as the offset is the same as stock.
Old May 6, 2016 | 01:07 AM
Most stock 570's come with 12" rims so shouldn't be any issues there. My wife's came stock with 12" steel rims and I put the 14" aluminum stock rims with 27's off my scrambler on. Only issue going to the stock 14" aluminum was I had to add 2" spacers to put the centercaps on.
Old May 6, 2016 | 08:32 AM
TLC's Avatar
TLC
I put 26x11 Zillas rears and 26x9 fronts on a Mid chassis 350 Yamaha Grizzly/Bruin with plenty of room to spare , I would think a full size chassis of a 570 sure could handle it.
Old May 6, 2016 | 05:37 PM
RticKwad's Avatar
Runs Stealth!
I pulled the plug and ordered ITP212 Black Matte 12" wheel set all 4 to include taxes and shipping out the door $285.
I'll post pics up once I have them mounted.
R'
weirdguy
May 31, 2016 02:26 PM
jeff.janor@gmail.com
May 29, 2016 04:45 PM
WIBigDan
May 4, 2016 04:58 PM
moparz
Apr 30, 2016 01:36 PM
