What's my cc,s?? Only marking is serial #
Old May 15, 2016 | 06:53 AM
Nick k's Avatar
Default What's my cc,s?? Only marking is serial #
Its off a tantrum x-100.4 stroke .I bought it with no carb,battery or gas lines.minor wire problem. Do I need to no the cc to buy a carb or can I get one that fits my intake
Old May 15, 2016 | 07:32 AM
If it's a Honda type clone,one size just about fits all. Or so the ad says.PZ19 19mm Dual Feed 50cc 110cc Carb 4 Stroke Horizontal Cylinder Honda Engine | eBay
Old May 15, 2016 | 07:00 PM
Nick k's Avatar
Default Old Polaris tec..got a ???
This atv has a dual throttle cable and one side of the cable bolts onto the top of the carb with two bolts not single screw on..and the fuel shut of is mounted to the frame,it is a 19 mm intake .I would appreciate the help
Old May 16, 2016 | 04:50 AM
Here's several page of 19mm carbs. If you can't find one that would work,then it must be one weird carb.19 mm atv carbs | eBay
Old May 16, 2016 | 06:50 AM
Nick k's Avatar
Default Found it thanks!
Attached Thumbnails What's my cc,s?? Only marking is serial #-screenshot_2016-05-16-07-44-09.png
Old May 16, 2016 | 07:22 AM
LT80's Avatar
LT80 Expert
You should find one with a manual choke.
Old May 16, 2016 | 07:29 AM
Nick k's Avatar
Default Lt80
If I get one with manual choke will it effect the electric starting???
Old May 16, 2016 | 07:37 AM
Nick k's Avatar
Default Lt80
Old May 16, 2016 | 10:31 AM
Sure you have a 4 stroke? The carb you're showing is mainly used on 2 strokes. Most 4 stroke carbs have the mounting flange with 2 bolts. Plenty of manual choke carbs like the one you listed but again they're for 2 strokes..
Attached Thumbnails What's my cc,s?? Only marking is serial #-s-l1600.jpg   What's my cc,s?? Only marking is serial #-19mm-carburetor-e-ton-2-stroke-rxl50-axl50-txl-viper-atv-carb-hand-choke-new.jpg
Old May 16, 2016 | 11:45 AM
Nick k's Avatar
Default Two or four stock??
