1988 suzuki quad runner lt4wd 250 issues
Old Jun 2, 2016 | 08:19 PM
Rangerguy's Avatar
Default 1988 suzuki quad runner lt4wd 250 issues
So I recently just pick my dad up a 1988 quad runner 250 awd the bike runs but it's getting way to much fuel backfiring will not idle it self down with idle screw carb has be completely redone I'm at a loss can anyone here help thanks a lot
Old Jun 3, 2016 | 11:01 AM
DirtDevil101's Avatar
So...if you are confident the carb is good to go...things get uglier from hear as I believe that quad is a thumper...and an almost 30y old thumper to boot. I've seen ignitions do crazy things as they die...so check the spark and ensure it's strong & constant when you crank the motor. After that...it's time to look at timing...some have timing ports to view others require more work...if you don't know the service history the timing chain, cam, lifters, valves could all need servicing...unfortunately, the thumper intake system is far more complex than a 2-stroke...
Timbo2500
Nov 29, 2022 08:37 AM
grapejuice420
Oct 26, 2017 06:48 PM
Maxwellturner
Apr 26, 2016 06:59 AM
Simon81
Apr 20, 2016 08:16 AM
Brandon Taylor
1) Engine problems..
8
Apr 1, 2016 07:37 AM
