Camshaft turning very hard on a bayou 220
Old Jun 15, 2016 | 06:08 PM
tiptopss's Avatar
Default Camshaft turning very hard on a bayou 220
I have the head off, got a ratchet on the cam gear, but it's very hard to turn over, when the valve is at it limit, it snaps hard then frees up until it touches the other valve. Any help? I can't figure it out
Old Jun 16, 2016 | 02:15 AM
That is how it is supposed to be, the cam lobes push the valve springs down, it takes quite a lot of force to do this. On multi cylinder engines, one or two valves will be pushing down while a couple of others will be pushing up but, on a single cylinder machine, you get all the force one way at a time. While you have the head off, check the cam lobes and follower faces for wear, and the cam bearings and rockers for wear and roughness.
Old Jun 16, 2016 | 07:03 PM
tiptopss's Avatar
Thanks. The valves are opening and closing fine, nothing looks bent. When the valve is all the way open, and starts closing it snaps loud and closes with a lot of force, both valves are the same way, before the other valve opens, the. can turns freely until it touches the next valve
Stealtharsenal
Jul 12, 2016 09:35 AM
donw
Jun 20, 2016 03:19 PM
QuadDaddy360
Jun 19, 2016 07:59 PM
abishoff
Jun 13, 2016 09:30 AM
TegraQuad
2) Chassis problems..
Jun 9, 2016 11:12 PM
