07 Polaris predator 500 stuck flywheel
Old Jun 16, 2016 | 01:32 PM
Brandon Stout's Avatar
Default 07 Polaris predator 500 stuck flywheel
I have a predator 500 that has the starter clutch going bad. Well I go to pull the fly wheel and it won't budge. And I'm using the impact gun to let the vibrations help me free the flywheel but it's not enough. Any help on how to get this thing off is appreciated
Old Jun 16, 2016 | 01:59 PM
At times it takes penetrant such as PB Blaster and heat from a propane torch around the crank shaft along with an impact gun to break these flywheels loose. Had the same problems on the Outlaw and KTM four strokes.SR Polaris Outlaw Predator 500 KTM 625 Flywheel Puller 33mm x 1 5mm | eBay Plus a good whack straight on the bolt while under tension can help.
Nigel Nicholas
Jun 15, 2016 12:07 PM
Wadetoombs
Jun 14, 2016 10:36 PM
Timbo2500
Jun 12, 2016 11:34 AM
tecate1987
Jun 1, 2016 10:01 PM
Luke Sandiefer
Technical and How-To Articles
May 25, 2016 05:51 AM
