1995 Yamaha Wolverine 350
Old Jul 22, 2016 | 01:48 AM
Hotrodn383's Avatar
Default 1995 Yamaha Wolverine 350
1995 Wolverine 350 4x4 acts like its stuck on a rev limiter but doesnt have one... very low power thru all gears. this year didnt have the Ebrake plug so that wont fix this one! Runs and idles great but low power ! New carb bout 6 months ago and have cleaned bt didnt help... new plug and all... any guesses?
Old Jul 23, 2016 | 07:20 PM
Hotrodn383's Avatar
Anybody?
Old Jul 29, 2016 | 01:01 AM
Hotrodn383's Avatar
If anyone has any idea please share....
Old Jul 29, 2016 | 02:41 AM
All you can do for a start is to check valve clearances, fit a new plug, and check if the old one is sooty or "death white." If that doesn't cure it, check compression, it should be over 90psi, clean the carb out again. If it still runs badly, you may have an electrical problem, coil, CDI, regulator, trigger coil or stator. The regulator can be checked by testing the volts across the battery with the engine running, over 15v and the regulator needs changing. Under 13v max, and either the regulator or stator is faulty.
Old Jul 31, 2016 | 04:50 PM
Hotrodn383's Avatar
Thanks for the info... i'll start somewhere... It just runs so good but rpm is limited to i'm guessing around 1500-2000rpms when i try to rev it up... no poping or backfiring! one thing i am wondering is the muffler has been gutted by previous owner.. will the lack of back pressure hurt it?
Old Aug 20, 2016 | 01:42 AM
Hotrodn383's Avatar
Fixed it !!!
Old Aug 20, 2016 | 04:08 PM
Then tell us how.
Old Aug 21, 2016 | 12:17 AM
hotrodster76's Avatar
The pin guide and spring fell out of the needle slide that works up and down in the top of the carb
P500
Apr 29, 2016 02:11 AM
Dennis0862
1) Engine problems..
Apr 26, 2016 08:20 AM
dahugo
Apr 26, 2016 08:13 AM
ragewraps
Mar 17, 2016 01:27 PM
