Buying an ATV Questions and suggestions about what to buy, financing, insurance, etc.
Checking valve clearnace and Gold Plugs
Old Jul 24, 2016 | 02:01 PM
bradleyheathhays's Avatar
Default Checking valve clearnace and Gold Plugs
Doing this for the first time on the old 2011 Grizz 700 and have a few q's?
I've found valve clearance specs as such...
Intake 0.09–0.13 mm (0.0035–0.0051 in)
Exhaust 0.16–0.20 mm (0.0063–0.0079 in)
If anyone can confirm that'd be great. I've been told to adjust the valve clearances to the top of the range in anticipation that they will tighten over time. This sound about right?
Are these the only two o-rings I'll need to replace? Both #18s in the schematic...
Yamaha ATV Parts 2011 GRIZZLY 700EPS 4WD HUNTER - YFM7FGPHA CYLINDER HEAD Diagram
And finally, which of those two valve covers are the intake and exhaust?
Also, was wondering about replacing my two gear box oil drain plugs and engine oil plug with the magnetic Gold Plugs. But at a price of $60 I'm wondering if they're actually worth it. Do people regularly find metal bits attached to these plugs?
Thanks
Old Jul 24, 2016 | 03:55 PM
hydrex's Avatar
I'd probably save the $120 and change the diff lube more often. I might set the valves in the middle, then check em again at 500 or 1,000 miles. # 18 looks to be the one, but when we did my Arctic Cat at 7,000 miles, just reused the old one...
Ean
May 8, 2016 07:42 AM
Logan1999
Yamaha Side by Sides
May 5, 2016 10:02 AM
cswiger
Apr 29, 2016 10:22 AM
Dennis0862
1) Engine problems..
Apr 26, 2016 08:20 AM
