Wiring accessories
I am looking for the best point to connect a switch for an LED light bar so that it is past the ignition. I have it wired to the terminal block under the hood now but it is always hot. Also going to add USB port and want both to disconnect when the ignition is off. 2015 Ranger 570.
Just hook the positive lead to a wire or terminal that is hot only with the ignition on. Usually this is a red/white wire on Polaris machines.Just use your test light or meter.
If you look into the harness loom you will probably find an auxiliary wire that's hot with the key on that's not used. It'd be better if you tied into something like that for the power if possible rather tying into other components wiring. Grounds can either be to the frame or tie into a group of browns. Doesn't really matter on that.
steelhead loco
Utility ATVs
Aug 8, 2016 08:18 AM
CumminsTurboDiesel
Jul 16, 2016 11:36 AM
SpeedyDean
Jul 13, 2016 08:48 AM
