I got bad gas...
Old Aug 13, 2016 | 12:29 PM
bradleyheathhays's Avatar
Default I got bad gas...
Life got the best of me this year and to make a long story short my '11 Grizz 700 has a half tank of gas (w/ no stabilizer) and hasn't been started for around 9 or 10 months. I have apologized to it and promised this will never happen again, but in the meantime I'm faced with what to do to remedy the problem. Ideally I suppose I should get the tank off and drain the gas, replacing with non-EtOH gas (which thankfully I just found in my area).
Any advice on how to get this done (draining the tank) or how difficult it might be?
Old Aug 13, 2016 | 01:06 PM
Kymco 450i's Avatar
In years past I have had to do this on more than one occasion. times flies past and before you know it months have passed. However it is not a hard thing to do. First off siphon as much fuel from your tank as you can, then look at the carb or fuel connection and disconnect the fuel line where it goes into your efi or your carb whatever type you have. Open your fuel line and allow this to drain the rest of the tank. I normally spray some carb cleaner into the carb inlet so displace any residue that may be trapped in there. After tank is drained flush with a small amount of fresh fuel and allow that to drain. Reconnect the fuel fittings and fill tank with fresh fuel and you should be good to go. My wifes atv sat for 2 years without running so I drained the tank and it started right up. Just done allow the old fuel to flow into the carb/efi system, that is why the disconnect to flush before trying to start.
Let us know how things turn out.
Old Aug 13, 2016 | 03:29 PM
Thanks kymco that sounds like a solid procedure. Hopefully I'll be able to get on this in the next week or so...and can finally start riding again!
Old Aug 13, 2016 | 03:54 PM
Another quick way to do this is with and air gun and shop rags.Stick a 1/2 or 3/4 drain hose in the tank,stuff rags around the opening and "gently" apply air to force it out the hose into a container. Can drain a tank in short time then you can use a grab it tool and shop rags to mop out the tank. We had to do that quite often on water contaminated water craft that held 8 gallons or more and starting doing the same on atvs.
Old Aug 13, 2016 | 07:42 PM
hydrex's Avatar
If it has a "Reserve" adjustment, put it on Reserve to get every drop. At least my Arctic Cat leaves 1.4 gallon or so if you just leave it in the On position. You might be able to dispose of the old gas at a local garage, if they have a waste oil furnace. 5 gallons of gas in 500 gallons of waste oil will burn ok. I used to have a "Clean Burn"
Old Aug 13, 2016 | 09:08 PM
Love that idea polaris tech. Either way I'm sure i'll be showering off after its all out but at least this way I'll have less work.
Hmmm yes that's a bit of a dilemma about disposing of the old gas. Maybe I'll put some stabil in it and mix it say a half gallon at a time per full tank into my Jeep. That sound risky maybe?
Old Aug 13, 2016 | 10:34 PM
user493's Avatar
Moto Psycho
I've used funky old gas mixed with a full tank of fresh gas in my truck and it didn't cause any problems. A half gallon at a time should be fine.
Old Aug 14, 2016 | 01:36 PM
Right. Thanks jf
Dezldog1
Mar 20, 2016 08:29 PM
bigdaddy01
Technical and How-To Articles
Mar 10, 2016 05:06 AM
Barnsnelbon
Mar 5, 2016 02:47 PM
CanadianViking
Feb 16, 2001 11:56 AM
cliffhangin
Mar 13, 2000 10:34 PM
